changing to gt40 manifold
  • Thread starter Thread starter 1quik69
  • Start date Start date Feb 17, 2006
1quik69
38
  • Feb 17, 2006
While my husband is out of town on a business trip, I thought I would ask for some advice on some changes he is doing on our 1995 Cobra project. I have purchased a gt40 manifold and an elbow adapter he says we need to use this manifold for his birthday. Is there anything else I need to get for this change he wants to make?
I
IntenseBlue
946
  • Feb 17, 2006
Not that I can think of.
Tonys96Cobra
professional deer "mounter"
Oct 28, 2005
29
Syracuse
Feb 17, 2006
  • Feb 17, 2006
Im pretty sure you can only use the gt40 intake with the gt40 aluminum heads (snicker, snicker)
JaysGreenLX
2,252
Buffalo, NY
Feb 17, 2006
  • Feb 17, 2006
You could always do a little port matching for him.
Black1987Stang
1,422
Jersey Shore
Feb 17, 2006
  • Feb 17, 2006
Throttle Body?
Matty469
77
Hawaii
Feb 17, 2006
  • Feb 17, 2006
Nothing says love like a set of gift wrapped 24# injectors!
old_blue
1,783
282
124
Feb 18, 2006
  • Feb 18, 2006
Parts for the IAC to fit if yours isn't pre-drilled for one. do a search and jrichter has the perfect method of doing this.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 18, 2006
  • Feb 18, 2006
Explorer /GT 40 Intake install
I got mine off a 96 Explorer with the 19# injectors and 65 MM throttle body for $250.
The ACT (Air Charge Temp) sensor will probably need to be moved. The GT 40 lower manifold isn't drilled & tapped for it to go into the intake like the stock manifold was. There is a boss cast into the GT 40, but a machine shop will have to drill & tap the new manifold. The best spot for the ACT is the air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
6 ft black 18 gauge wire
6 ft green 18 gauge wire
6 ft 1/4" heat shrink tubing
1 ft 3/16" heat shrink tubing
Measure the 2 extender wires & cut them to length, crimp one set of pins on them. Then mate up the extender pins with the wiring harness & slide the 3/16" heat shrink tubing over them & shrink the tubing. Then slide the 1/4" heat shrink tubing over the pair of wires and shrink the tubing. When you are done you'll have about 1" of wire left without heat shrink tubing on it to strip & crimp the new pins on. Stick the new pins in the old connector shell, assemble it and you are done. It looks as good as factory. Some wire loom can be used to enhance the "Factory Look".
Use the TPS and IAB from your old throttle body. All the EGR passages were there and fit OK. Use you old fuel rails and regulator. You will probably need a new EGR spacer adapter and gaskets. Without the EGR spacer, there is no place to mount the throttle linkage support bracket.
I used the stock water lines on the Explorer manifold and they connected up to the EGR without any problems. I made a “U” out of ½” copper pipe and sweat soldered it together. Then I used it and some hose with clamps to bypass the leaky heater I have. You don't need heat very often here in Central Florida...
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Cap or plug the remaining lines since they aren't needed.
Here's some tips...
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. Wala! no leaks, and no gaskets that shifted out of place.
If you reuse the injectors from your old setup, a repair kit is available from most auto parts stores if needed. Coat the injector body "O" rings with oil before you use them and everything will slide back together. Take the other advice you got here and run with it.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Consumable items:
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
5.0 Nostalgia
904
CT
Feb 18, 2006
  • Feb 18, 2006
I am confused. If your car is a 95 Cobra, it already has the GT40 lower. The upper is almost as good so why change it? If you want the GT40 upper, all I would think you have to do is swap that.
1quik69
38
#10
  • Feb 18, 2006
  • #10
changing to gt40 intake
He bought this car from a fellow that works with him for $900. It has been sitting for about 6 years. My husband says that the cam is flat and it is missing the complete intake manifold. The body and interior are all very nice and it only has 61,000 miles on it. Thanks to all of you for answering my question.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Feb 19, 2006
#11
  • Feb 19, 2006
  • #11
Will you divorce him and marry me? Please?
1quik69
38
#12
  • Feb 19, 2006
  • #12
Poopdawg, I can only afford one husband. We will have been married for 34 years come this august. We have survived 5 company downsizings between us, 13 years of racing NHRA stock eliminator, 2 kids and all the other normal disasters. Thank you for the offer, but I think I will stick with my current partner. It's a habit I don't want to break. He will be home Tuesday night and I think he will be really surprised. He has an explorer intake that he wants to get rid of because the GT40 setup looks cooler. Again, thanks for everyones help.
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Bought a 2001 GT from My Son
  • Hawkester
  • Oct 17, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 17, 2025
gkomo
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
