  • 1994 - 1995 Specific Tech
CHARGING PROBLEMS
  • Thread starter Thread starter howiefisher
  • Start date Start date Sep 1, 2007
howiefisher
154
Ont Canada
Sep 1, 2007
  • Sep 1, 2007
I have a 95 gt 5spd also has a pully kit now i only have 11 volts at the battery and 11.8v while running and battery light is on .and it is cutting out at high rpm i think its the altanator it does not seem to be charging any more .I should have like 14.6v while running right i bet its that dam alt pully that killed it .
howiefisher
154
Ont Canada
Sep 1, 2007
  • Sep 1, 2007
also when i rev it up the light used to go out now it stays on steady and the volt guage stays at like 11v it used to up as the rpm went up .now it stays still no movment evenif i rev it to 5500rpm
HISSIN50
34
129
Sep 1, 2007
  • Sep 1, 2007
I'd have the system tested at the parts store for free. This will help you narrow down and confirm what is failing exactly. Also be sure the alt fuse isnt blown, nor the two fusible links on the OEM charge cable.
Good luck.
toyman
1,944
54
79
Vernon BC
Sep 1, 2007
  • Sep 1, 2007
I don't think a larger U/D pulley will kill an alternator. Things though do wear out, fuses blow and batteries die. Is it the original alternator? Mine lasted 12 years before it quit.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
Fox Jump/start - Charging
  • PonyGTrider
  • Oct 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
PonyGTrider
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
