CHEAPEST 5-LUG CONV. ???
  • Thread starter Thread starter DirtyD916
  • Start date Start date Jun 27, 2004
DirtyD916
804
Norcal 916
Jun 27, 2004
  • Jun 27, 2004
just lookin around for the cheapest 5 conv. for a fox-body. Its a 1989 if it helps at all.
p.s. did the search button and couldnt find any real good info.
motley
33
  • Jun 27, 2004
Latemodel Resto has a kit for $399 I believe. I'm thinking about going this route.
5.0guy
320
MI
Jun 27, 2004
  • Jun 27, 2004
depends on what rims u want.
88stangmangt
2,332
Stafford,VA
Jun 27, 2004
  • Jun 27, 2004
yep..................
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 27, 2004
  • Jun 27, 2004
Cheaper still...
See Matt90GT's Site, http://www.svo73mm.cjb.net/ for help
trbkrb
1,976
Houston, TX
Jun 27, 2004
  • Jun 27, 2004
Depends on what wheels you want to run as to the way you convet, since most of the 96+ 17" Mustang wheels will not work well with the SVO/ Mark VII rotors in the LMR kit. Also depends on if you want to search for parts or just pay to have them delivered to your door. For reference, I can duplicate the LMR kit with used parts locally for around $100 or so at our pick a part yards. With Ranger rears and 96+ SN95 fronts it would run me around $200.
SmockDoiley
1,591
San Diego, CA
Jun 27, 2004
  • Jun 27, 2004
Dont do the lincoln rear disc conversion, its garbage!!! Both my rotors are warped now and I dont have the money to change anything so I'm screwed. As for the fronts, you can run any rim you want. If you dont believe me then go to my cardomain page and check out the 99 cobras I have on my Lincoln 5 lug front rotors. I only needed a 7/8th spacer and moroso longer wheel studs. It runs just fine, and the rims dont stick out at all, and if anything it gets the tires away from the inside so I have no rubbing problems even with my lowering springs. The spacers ran me about $40 and the studs I think were like $15.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Jun 27, 2004
  • Jun 27, 2004
Damn, I wish you would get me those parts and sell em to me for that. I would even pay you to get em, must be nice to have those junkyards plentyful. Oh well, maybe someday.
Dave
bmorrisj
449
Buena Park, CA
Jun 27, 2004
  • Jun 27, 2004
try to avoid using spacers...its just a bandaid fix...
DirtyD916
804
Norcal 916
Jun 27, 2004
#10
  • Jun 27, 2004
  • #10
i was thinking the baer system because of the quality fit and finish but damn $1000+ without install. Thats alot for me.
bmorrisj
449
Buena Park, CA
Jun 28, 2004
#11
  • Jun 28, 2004
  • #11
aww crap... forgot there is a company that makes replica wheels that fit the 70+mm bore on the lincoln rotors...
SmockDoiley
1,591
San Diego, CA
Jun 28, 2004
#12
  • Jun 28, 2004
  • #12
Theres nothing wrong with spacers. Some of the best companies sell spacers and I know a lot of drag racers and autocross guys who use them so they cant be bad. I've got several hundred miles on my setup and it works fine. You can use any rim you want with Lincoln brakes. Since you havent tried it like I have I think that makes me more qualified to know if it works or not.
87'GTstang
1,025
#13
  • Jun 28, 2004
  • #13
Put it this way, if you can avoid using spacers, by all means - avoid them.
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
