  • SN95 4.6L Mustang Tech
Check Engine Code P1132....
  • Thread starter Thread starter 97GTSTANG
  • Start date Start date Aug 9, 2004
97GTSTANG
852
Virginia
Aug 9, 2004
  • Aug 9, 2004
I have searched and most of the info i received are from people who just had their headswap done and now getting the P1132 code. The guy at autozone said its a code P1132 Fuel Air Meter. Dont know what to replace or what it could be. ANyone else have this expereice. I just got my headswap done too.
Thanks
A
AquamanCHS
122
N. VA
Aug 9, 2004
  • Aug 9, 2004
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1.
Means problem with passenger side oxygen sensor, upstream of the cats. I had a similar code (P1131) and I replaced the sensor, no problems now. Are you running rough? Rough idle? Surging while cruising? I'd say replace the sensor and see what that does.
rpayne20
77
MI
Aug 9, 2004
  • Aug 9, 2004
where can you get a list of all the codes and what they mean????? anyone know????
A
AquamanCHS
122
N. VA
Aug 9, 2004
  • Aug 9, 2004
Right here on this site
Search is a wonderful thing
97GTSTANG
852
Virginia
Aug 9, 2004
  • Aug 9, 2004
but i think i replaced the o2 sensors last year. could it possibly be the bassani x cats that are going bad?
A
AquamanCHS
122
N. VA
Aug 9, 2004
  • Aug 9, 2004
Remember you have two sets of O2 sensors.
One set is right after your exhaust manifolds (upstream) and one set is after your cats (downstream). So if the sensors before the cats are getting odd readings then it's probably not the cats (at least I wouldn't think, I could be wrong... though I have heard Bassani cats = )
Either way, good luck figuring it out.. I've told you all I know on the subject
97GTSTANG
852
Virginia
Aug 9, 2004
  • Aug 9, 2004
thanks, well when he pulled the code P1132 it also said fuel air meter, so i was thinking its the Mass air.
J
Jake795
110
  • Aug 9, 2004
I just had my codes pulled today and i remember them saying something about the fuel air meter too. I also recently just swapped my heads. I think mine was 2 different codes. One for the O2 sensors and the other for the fuel air meter. If someone knows more about this please post
Jake
97GTSTANG
852
Virginia
Aug 10, 2004
  • Aug 10, 2004
yea. i think the headswap is causint this P1132 code. I have also heard to clean the MAF with brake cleaner or something like that. Am i correct?
J
Jake795
110
#10
  • Aug 10, 2004
  • #10
I'm not sure what to clean them out with. I wonder what is it about the headswap that is causing this code to be thrown. I really need to get this thing straight so i can get my inspection sticker.
jake
97GTSTANG
852
Virginia
Aug 10, 2004
#11
  • Aug 10, 2004
  • #11
i read somewhere that the car is trying to compensate for an overlean condition. not sure. I am going to clean the MAF and see how that works out. Can the Fuel Injectors be cleaned out, or should i just replace them?
smallz33
14
#12
  • Jun 16, 2010
  • #12
put some injector cleaner in your tank on next fillup .. tht will clean them ...y a you can use brake cleaner adn or electronics cleaner..wouldnt hurt to replace fuel filter i know i nee to mines rusted to hell.. thats why tehy call um rustangs
G
GDTrumbo
199
Nashville, TN
Jun 16, 2010
#13
  • Jun 16, 2010
  • #13
Use the MAF sensor cleaner specifically for MAF sensors. CRC seems to be the most common. Carb/brake cleaner is way too strong and can destroy it.
GT
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 17, 2010
#14
  • Jun 17, 2010
  • #14
P1132 - Lack of HO2S-11 Switch
Why did you perform a headswap? Did any anti-freeze/oil get into the exhaust? If so, possible that has ruined the O2 sensor.
P1132 - Lack of HO2S-11 Switch, Sensor Indicates Rich
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit
The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit.
Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
Code p0204
  • 04blckstang
  • Nov 23, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
