P1132 - Lack of HO2S-11 Switch
Why did you perform a headswap? Did any anti-freeze/oil get into the exhaust? If so, possible that has ruined the O2 sensor.
P1132 - Lack of HO2S-11 Switch, Sensor Indicates Rich
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit.
Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
