  • SN95 4.6L Mustang Tech
CHECK ENGINE... it turned off?!?!
  • Thread starter Thread starter supastang03
  • Start date Start date Feb 4, 2006
1 of 2 Next Last
supastang03
214
Miami/Gainesville UF
Feb 4, 2006
  • Feb 4, 2006
ive had my Prochamber o/r H pipe on for almost 2 years now, and the check engine light has been on just as long. all of a sudden, the other day, it turned off..never to return..at first i thought the bulb blew, but it lights up when i crank the car...what could have caused this??
01Steeda
732
Baton Rouge, LA
Feb 4, 2006
  • Feb 4, 2006
your car gave up lol
XXBULLETSXX
301
Kannapolis, NC
Feb 4, 2006
  • Feb 4, 2006
I wish mine would give up too!
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 4, 2006
  • Feb 4, 2006
thats odd. only a ford powertrain engeneer could answer that one. it must have to do with the programing.
tomustang
Psychotic Member
3,434
McLean Hospital
Feb 4, 2006
  • Feb 4, 2006
For 2 years your CEL has been on and you never checked the code?
merc123
420
North GA
Feb 4, 2006
  • Feb 4, 2006
lol
he's right, it did give up. the car just said f-it.
D
d90212
253
kailua, hawaii
Feb 4, 2006
  • Feb 4, 2006
after so many drive cycles if it doesnt see the same error/code it erases it.
Mike97gt
it doe snot
10,633
Feb 4, 2006
  • Feb 4, 2006
2 years of drive cycles is a little extreme. it;s only a couple of cycles without a fault for most monitors.
only thing i can think of is somehow the sensors are in range now.
M
MAXX RS4
83
  • Feb 4, 2006
Maybe your sensors are so gummed up with rotten egg smelling stuff that it can't even detect any of it at this point?
D
d90212
253
kailua, hawaii
Feb 5, 2006
#10
  • Feb 5, 2006
  • #10
your right, straight from the horses mouth, PCED
The OBD-II system monitors for malfunctions either continuously, regardless of driving mode, or non-continuously, once per drive cycle during specific drive modes. A pending DTC is stored in the PCM keep alive memory (KAM) when a malfunction is initially detected. This pending DTC may be erased on the third vehicle restart after two consecutive drives cycles with no malfunction. However if the malfunction is still present after two consecutive drive cycles, the MIL is illuminated. Once the MIL is illuminated, three consecutive drive cycles without a malfunction detected are required to extinguish the MIL. The DTC is erased after 40 engine warm-up cycles once the MIL is extinguished.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Feb 5, 2006
#11
  • Feb 5, 2006
  • #11
Good info!
Mike97gt
it doe snot
10,633
Feb 5, 2006
#12
  • Feb 5, 2006
  • #12
this is really strange how this check engine light turned off.
I wonder if ford programmed it to turn off the cat monitior system if the light stays on for a extended period of time ( like 2 years) 2 years is long enough to go thru state inspections a couple of times. and if you dont live in a emmisions state you may not bother fixing it.
F
fatkidracing4.6
20
Canton,Oh
Feb 5, 2006
#13
  • Feb 5, 2006
  • #13
so if that is the case then disconnect the battery to clear the computer and it should fire right up! I am gonna lay a bet down that maybe your fuel pump went out! Or something like that! Start from the begining are you getting spark? Are you getting fuel! Don't narrow down your options with guesses it makes fixing it alot harder!
Andrew
01Steeda
732
Baton Rouge, LA
Feb 5, 2006
#14
  • Feb 5, 2006
  • #14
Andrew
He didnt say it doesnt run
Black Stang 97
the guy on top of me is funny
Nov 11, 2004
483
Los Angeles, CA
Feb 5, 2006
#15
  • Feb 5, 2006
  • #15
ive had 2 stangs,97 GT and 97 Cobra both with o/r bassani and the CEL never goes on?
propellerhead
1,541
"but what's with the but shots?"
Feb 5, 2006
#16
  • Feb 5, 2006
  • #16
Really strange. Please post the final answer.
... subscribing.
supastang03
214
Feb 5, 2006
#17
  • Feb 5, 2006
  • #17
i cant figure it out at all...all your guessing have been pretty insightful thoughts guys, thanks. it still hasnt come back on, which is weird. i recently installed a whiteface guage overlay, which required disconnecting the gauge assembly...however, the light was still on when i connected it back again, and shut off only a couple days later. maybe this has something to do with it? i dunno...weird, but im glad that thing is finally off.
oh yea, and theres no emmisions testing in Fl...
Mike97gt
it doe snot
10,633
Feb 5, 2006
#18
  • Feb 5, 2006
  • #18
this one has me stumped. now that i think of it there is no way ford would have programmed it to give up after a few years. just in case the car was resold in a emissions state. the only other thing i can thing of is both sensors are stuck within the limits of a normal reading for the cat monitors. since the cat monitor 02's don't switch this will not lead to other 02 sensor codes (circuit malfunctions, slow response)
L
laser2kgt
237
Laredo, TX
Feb 10, 2006
#19
  • Feb 10, 2006
  • #19
when i first got my x-pipe and flows, the light didnt go on til like a week later. after a pair of months with the cel, it went off then went back on a few hours later. wtf?
supastang03
214
Feb 10, 2006
#20
  • Feb 10, 2006
  • #20
ok great...just came back on. yesterday. i was kinda spoiled before without the ugly yellow light in my face, and now it just came back again. wtf? this has me completely stumped.
1 of 2 Next Last
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
