ok i'll try to cut to the point. i have a 94 5.0 that is not running right. This started after i got the exhaust put on (longtubes, xpipe no cats, flow muffs). The car idles rough, like the idle comes up and down and sometimes dips so low it almost stalls the car, but sometimes idles fine. And after driving it for a while the CEL comes on. So i ran the code, and got 314, 311, and that cylinder 6 was failing when i did cylinder balance test. So i checked out the exhaust work and everything seemed to be pretty much back in place where it was on the stock exhaust, except the cats, and the plumbing coming from the smog pump going to the hard pipe between the heads. So i tracked down those parts (hoses and two diverter valves) and put them on last night. When I was test driving car after about 15 minutes the CEL came on again. now i'm going to run the codes when i get home from work but i was wondering if anyone could point me in the right direction. i'm fairly new to working on my stang so any help is greatly appreciated.
also, in the meantime while i was trying to get car right (after the exhaust was put on) i installed bbk 70mm TB and MAF. dont know if this may have anything to do with it
