check engine light after installing 95GT MAF
mob
the guy who hits on his mom
Oct 3, 2003
2,566
136
104
Dallas, TX
I just finished cutting the flange off my 95GT MAF and I hooked everything back up, made sure everything was real tight so there was no leaks. When I start my car it surges real bad from about 600 to 1200rpm and about 2 seconds later I get a check engine light that stays on. And I cant check what the code is because every time I jump the eec with a wire and turn the key the check engine light just blinks once and doesn't do anything. Im pretty pissed that every time I do something my car never likes it. I could change a head light in my car and it wont run for days.
If my stock one works, does that mean its probably the sensor thats bad? Its the -AA sensor.
Yes, unless you have some twisty turns in the intake ducts.
Remember that the sensors are not interchangeable between different types of housings.
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
Well I am using the stock air box right now. I got the MAF from my work. If I defect out the sensor, can a I put the new sensor back in the other housing I got? I cut off the flanges so I want to just swap out sensors not the whole thing. Itll be a 95 sensor going in a 95 housing, or is each sensor made for each specific housing?
As long as the housing is the same type or has the same part number, you can put a replacement sernsor on an old housing.
