check engine light no codes
  • Thread starter Thread starter jhonda
  • Start date Start date Nov 15, 2007
jhonda
125
Huntersville NC
Nov 15, 2007
  • Nov 15, 2007
I tried pulling the codes but none show up...I have a 91 mustang that I bought from my dad and it has been doing it for the past 30000miles. The check engine light will come on and go off about every 5-8seconds while in the city below 40mph but the faster you go the more it flashes.....now when I say flashes it stays on for about 5-7seconds.
any ideas
jason
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Nov 15, 2007
  • Nov 15, 2007
I had an intermitten engine light problem back a few years. No codes.
Turned out to be the o2 sensors, only reason it was figured out what when removing my x pipe, we broke one. And when i put a new one in, it never happened again.
HISSIN50
34
129
Nov 15, 2007
  • Nov 15, 2007
Do you literally get 'no codes' or do you get a system pass (11)?
ninety15.0
1,336
  • Nov 15, 2007
Oh thats a good point. Also what tests have you done?
I would try inducing an obvious code. Unplug the MAF, TPS, or O2 sensor and then do all diagnostic tests.
Then i would pull a plug off and run the cylinder balance test. This should help you verify that the computer is functioning properly. good luck man.
jhonda
125
Huntersville NC
Nov 15, 2007
  • Nov 15, 2007
yes I get a system pass but no fault codes
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 16, 2007
  • Nov 16, 2007
Have you dumped the codes with the engine running? You will often find different things.
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
