check engine light no codes
jhonda
125
Huntersville NC
I tried pulling the codes but none show up...I have a 91 mustang that I bought from my dad and it has been doing it for the past 30000miles. The check engine light will come on and go off about every 5-8seconds while in the city below 40mph but the faster you go the more it flashes.....now when I say flashes it stays on for about 5-7seconds.
any ideas
jason
I had an intermitten engine light problem back a few years. No codes.
Turned out to be the o2 sensors, only reason it was figured out what when removing my x pipe, we broke one. And when i put a new one in, it never happened again.
Oh thats a good point. Also what tests have you done?
I would try inducing an obvious code. Unplug the MAF, TPS, or O2 sensor and then do all diagnostic tests.
Then i would pull a plug off and run the cylinder balance test. This should help you verify that the computer is functioning properly. good luck man.
