  • 1994 - 1995 Specific Tech
Check engine light on hard accelerating
  • Thread starter Thread starter 94WizStang
  • Start date Start date May 14, 2006
94WizStang
Beaufort S.C.
May 14, 2006
  • May 14, 2006
Help!!! Anyone have this problem?? my check engine light comes on when I get on the gas(and who does'nt) and goes back out when I level my speed out. The engine performance is not affected what so ever and have had it put on a tester and get zero fault codes. Any clues?
giddyup306
3,041
May 14, 2006
  • May 14, 2006
You probably have a grounding issue. What kind of scantool did you use? To make sure you might want to have it tested at a ford dealership. The WDS and NGS that they use will display a LOT more codes and PIDs than any generic scanner (even if it's Ford enhanced).
SOme older lincoln are known for flashing the DLC light after EEC testing. The dash simply has poor wiring.
Like you said if there is no probem (other than the obnoxious flashing light and can deal with it) don't worrie about it. Mind you if you go to a dealership to have it fixed they will probably charge you straight time. That can get pricy fast.
94WizStang
Beaufort S.C.
May 14, 2006
  • May 14, 2006
Took it to Ford and their machine kicked no code faults. They recommened that I leave it for a full tune up and run it again. I just had a full tune up and a rebuild on the tranny. I also had a new radio installed and they rerun my battery ground which I am going to put it back where it is mounted to the underside due to engine static in the radio. Could that be part of the issue? It started not long after that.
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
