  • 1994 - 1995 Specific Tech
Check Engine light problem
  • Thread starter Thread starter Black95GTS
  • Start date Start date May 19, 2005
Black95GTS
1,644
Marlborough, MA
May 19, 2005
  • May 19, 2005
When I start driving hard, the CE light will pop on for about 30 seconds then go away when i stop beating on her.
I pulled the codes and it came up perfect.
This ONLY happens when I start to stomp on the pedal. Normal driving never triggers the CE light.
Any ideas? I don't have cats on the car, so maybe it has something to do with that?
thanks,
Adam
glenn95gt
420
Bay Area, California
May 19, 2005
  • May 19, 2005
might be running rich
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 19, 2005
  • May 19, 2005
thanks,
Adam
You might have a wiring problem at the CEL blub. If you are running the codes right, that is. Make sure you do the KOEO, and KOER codes as well. Follow the procedure lined out in the haynes manual.
Scott
HISSIN50
34
129
May 19, 2005
  • May 19, 2005
Agreed with Scott. if the CEL was triggered, there should be codes stored. That is unless you dont have constant power to the KAM.
good luck.
Black95GTS
1,644
Marlborough, MA
May 26, 2005
  • May 26, 2005
Sorry for the late response fellas, I just graduated college and I have been a little busy lately. (Bachelors in Electrical and Computer Engineering!!)
Anyway, I ran the codes with my cheapo system, all clear. My uncle, who is a mechanic scanned my car with the machine at his shop. Everything comes up all clear, no codes stored.
What does KAM stand for? And where is it located? Excuse my nubishness.
thanks fellas,
Adam
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
May 26, 2005
  • May 26, 2005
Why dont you get a $25 scanner from Walmart and check it out?
RC
Black95GTS
1,644
Marlborough, MA
May 26, 2005
  • May 26, 2005
I have a 25 dollar scanner. My uncle has a 700 dollar scanner. Still nothing, still have the CE light after WOT runs.
HISSIN50
34
129
May 26, 2005
  • May 26, 2005
good luck.
asked again.
JJ95GTID
1,141
Phoenix, AZ
May 27, 2005
  • May 27, 2005
KAM=Keep Alive Memory
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
