U uneedav8 New Member Apr 6, 2008 25 0 0 May 11, 2008 #1 May 11, 2008 #1 I am getting a check engine light after a few seconds of starting up the engine. It will not pick up any codes during a scan......even after resetting the battery. My car is a 93 GT.Any help would be appreciated.
93 LX Founding Member Jun 2, 2000 3,081 3 0 Norwalk, CA. May 11, 2008 #2 May 11, 2008 #2 check engine should have codes. resetting the ecc blew out any codes you had. Whic tests did you try? KOEO or KOER?
joel5.0 Member Jun 15, 2004 429 2 18 Puerto Rico May 11, 2008 #3 May 11, 2008 #3 No codes as in codes 11 OD and CM in a KOEO, or "no codes" as in no output from the EEC?
U uneedav8 New Member Apr 6, 2008 25 0 0 May 11, 2008 #4 May 11, 2008 #4 Thanks for the reply.....I ran the KOER test with a code 11 but can not get rid of the check engine light.
