  • 1994 - 1995 Specific Tech
check engine light
  • Thread starter Thread starter TRIKY9116
  • Start date Start date Aug 14, 2006
T
TRIKY9116
  • Aug 14, 2006
hello all, 1 have a 94 gt the check engine light came on. ran the codes came up with code 332 which is issuficient egr flow. changed the egr and sensor cleared the codes and the engine light came back on. any ideas?
also codes 564 and 10 came up which are engine temp circuit relay and cylinder 1 trouble any ideas there as well.
HISSIN50
34
129
Aug 14, 2006
  • Aug 14, 2006
Is there a vac source to the EGR? If it looks good, I'd check the EVR - both electrically and make sure there's manifold vac in and switched vacuum out.
Good luck.
MysteryMachine
1,835
Parkesburg, PA
Aug 14, 2006
  • Aug 14, 2006
check the little plastic vac lines thats run to the egr valve if them snap you will throw that code.
95opal
5 Year Member
Nov 16, 2004
449
20
39
Aug 14, 2006
  • Aug 14, 2006
T
TRIKY9116
  • Aug 22, 2006
THANKS FOR ALL THE HELP. IT ENDED UP BEING THE CONNECTION OF THE THREE VAC LINES.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
