  • SN95 4.6L Mustang Tech
Check engine light
  • Thread starter Thread starter bluesonic
  • Start date Start date Sep 20, 2006
bluesonic
Mooresville, N.C.
Sep 20, 2006
  • Sep 20, 2006
Been having problems with code 0153 "Slow response" WE have replaced the O2 sensor twice. The last time everything was ok for about 6 wks then it came on again. The dealership says the driver side sensor is not responding at all and showed me the flatline graph. I have a Bassani x-pipe with hi flow cats with mil eliminators and a custom tune. The dealershipoe will be no help because they say the car has been modified. Any suggestions?
EDIT
The dealer's computer showed possible troubleshooting tips with PO153 could be electrical short or exhaust leak if not the sensor.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Sep 21, 2006
  • Sep 21, 2006
I deleted your other thead because we do not need multiple threads for the same problem and it would just confuse people. Just post updates of this problem in this thread. I posted the info you put in the other thread in your original post above.
Well anyways. that is a slow response on sensor ho2s21 or the upstream sensor on the drivers side.
If you have a exhaust leak you could get this code. Also if the sensor is not getting hot enough you might get this code. If you do not have a exhaust leak I would test voltage on the heater circuit of this sensor. If you are not getting full power to the heater circuit then the sensor might respond slowly.
Is there any other problems you are having, like bucking,hesitation,misfires or anything else.
bluesonic
Mooresville, N.C.
Sep 21, 2006
  • Sep 21, 2006
The two other things I think I've noticed is that the engine idles a little "rough" for a few minutes after a cold start and I don't know whether its my imagination or not but the exhaust on the driver's side has a stronger, more acrid smell, you know , kind of burns your nose a little. Like I said, I don't know if I'm just imagining it since I knbow something's wrong or not. Thanks for your response. I'll try to check that other stuff out too.
Bluesonic
Mike97gt
it doe snot
10,633
Sep 22, 2006
  • Sep 22, 2006
Bluesonic
it is possible to smell a difference in the exhaust even with cats if you have fuel mixture issues. If a lot of fuel is being dumped down to the cats the reaction of that can cause a difference in exhaust smell.
M
MBDiagMan
171
Lamar County, Texas
Sep 22, 2006
  • Sep 22, 2006
Check the heater circuit to the O2 sensor. Additionally, it might require replacing the sensor.
If you have changed headers relocating the sensor, this might be your problem.
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
L
2004 Mustang Oxygen (O2) Sensor Issue
  • letumeternum
  • Dec 30, 2024
Lexiii12
L
  • dan50
  • Jul 18, 2026
dan50
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
2K
Other Auto Tech Jun 24, 2024
Wallyman
