Check Engine?!
  • Thread starter Thread starter jtstang89
  • Start date Start date Jul 3, 2004
jtstang89
48
Oklahoma
Jul 3, 2004
  • Jul 3, 2004
Check Engine?! O2 sensors?
My car has the stock h-pipe with gutted cats. After about running it for approx. ten minutes, my check engine light comes on. I ran a diagnostic on it, and I got back the code for the O2 sensors. This may seem like a stupid question, but can I correct it by simply replacing the sensors? or am I screwed do to the fact that my cats are no longer there? I'm a pretty big retard when it comes to cars, so I appologize for my ignorance. Any help is greatly appreciated.
Ourobos
260
Jul 3, 2004
  • Jul 3, 2004
Yeah, most likely just replace the sensors. Solved my engine light.
HISSIN50
34
129
Jul 3, 2004
  • Jul 3, 2004
i would make sure im not running lean first (bad FP, regulator, etc), if you tossed both O2's. it could be the sensors, but since you got both, it could be a primary fuel issue - the lambdas only 'read' what the engine is putting out. if the engine does not have the right amount of 'food', the lambdas reading can reflect that.
lambdas should be 0.1 to 1.0 volt - less voltage is leaner. they do go bad over time, and they also get to be slower to react.
just some info. good luck.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
