  • 1994 - 1995 Specific Tech
checked codes, could be wrong
  • Thread starter Thread starter Mustangless
  • Start date Start date Jul 30, 2005
Mustangless
903
home
Jul 30, 2005
  • Jul 30, 2005
I just tried checking my codes without a scanner and got 332. I am not sure if I got that right but it could be. I have searched and read that you can elimanite it. How hard is that to do and how do u do it? Also would this be hurting performance? My car will not even spinout.
CManT1914
3,172
Killeen, Texas
Jul 30, 2005
  • Jul 30, 2005
Insufficient EGR flow right? I think I have that now that I no longer run EGR. Do you still have the EGR hooked up? I would think that the valve is stuck closed or something. Might wanna check it out. If you decide to delete the EGR, then the only real way to not throw a code anymore is to delete it from the PCM. Good luck
HISSIN50
34
129
Jul 30, 2005
  • Jul 30, 2005
The EGR increases fuel efficiency via allowing inert gasses into the chambers. This cools the chambers, allows timing to be advanced a decent amount, and allows injector pulsewidth to be pulled back. Yet it is not functional at WOT, so no WOT performance detriment.
The only reason I would remove it would be for aesthetics. And I would only remove it if turning off the EGR function in the computer. The resistor and plunger tricks are generally only to trick the CEL.
GT's have enough detonation issues without introducing another spot for more to creep in - If EGR is removed but the puter does not know about it, there is no inert gas diluting the mixture, while there remains more timing and less fuel (which would be proper if EGR was present).
Hmmm, seems to me that this is a reason GT's ping as it is.
Just my unpopular opinion.
NOTE that not everyone sees detonation at part throttle after EGR removal. But I would be prepared to deal with it, should it pop up.
Good luck.
CManT1914
3,172
Killeen, Texas
Jul 30, 2005
  • Jul 30, 2005
Good luck.
I agree completely, the only reason I removed mine is because the tube wouldn't reach the intake after the new H/C swap, and I had to cut the pipe to get it off. But if you DO have a faulty EGR, and access to a tuner, then taking it off and deleting it from the computer shouldn't hurt performance or lead to detonation. Plus it's usually easier just to take it off than to put a new one on.
HISSIN50
34
129
Jul 30, 2005
  • Jul 30, 2005
Well said and agreed.
E
extremetrek
106
Prescott, AZ (66.6%) Central Point, OR (33.4%)
Jul 30, 2005
  • Jul 30, 2005
I got that same code after my intake swap. I guess while I was removing the connection to the elbow I broke the little green plastic-like tube. I simply fixed the break in the tube and the code went away. If you want a picture I can get you one, but its just a little green tube that I believe plugs into the intake elbow.
Of course you could just remove the EGR as talked about above....
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
G
1995 Mustang GT- No PCM Communication, Runs Rich, Lacks power
  • gtrob
  • Aug 30, 2025
1994 - 1995 Specific Tech Aug 31, 2025
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
