checked front rotor runout
  • Thread starter Thread starter rockyracoon
  • Start date Start date Apr 30, 2006
R
rockyracoon
874
27
49
margate NJ
Apr 30, 2006
  • Apr 30, 2006
Im trying to track down the source of the front wheel shimmy and brake pedal pulse when brakes are applied.I checked the runout inside and out of the new rotors and they are showing .002-.003 max, is that too much? there is no play in the front end components at all,wheel bearings are also good.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Apr 30, 2006
  • Apr 30, 2006
Well, does the steering wheel shake under braking? Or is it through the rear of the car? Just because the rotors arn't warped doesn't mean the brakes aren't causing the problem. What is the condition of the surface of the rotors? Any hotspots (darker spots or areas of the rotors) is the surface blue?
R
rockyracoon
874
27
49
margate NJ
Apr 30, 2006
  • Apr 30, 2006
yes the steering wheel shakes a little.It is just when the brakes are applied and the pedal pulses as well it is definetly the front brakes and the rotors are new.but is that runout acceptable?
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Apr 30, 2006
  • Apr 30, 2006
warped rotors wont usually cause a brake pedal pulsation on our cars since it has floating calipers. but thickness variance will. measure the rotor side to side with a micrometer in like 12 places and see if the numbers are the same. also, brake drums that are out of round will cause a pedal pulsation. just a few ideas for ya
R
rockyracoon
874
27
49
margate NJ
Apr 30, 2006
  • Apr 30, 2006
well I think I can rule out the drums cause If I just apply the emer brake I dont get any of the symptoms,but thanx for the heads up on the rotor thickness,ill check that next.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Apr 30, 2006
  • Apr 30, 2006
that .002-.003 inches of runout is fine. check to see if there is any endplay in the rotors. maybe the bearings are worn out and are causing it.
R
rockyracoon
874
27
49
margate NJ
Apr 30, 2006
  • Apr 30, 2006
any chance that the new races that were in the new rotors are not compatable with my original bearings?
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Apr 30, 2006
  • Apr 30, 2006
well i would have replaced the bearings since they probably had a wear pattern worn into them and they will either wear out the races or wear themselves out if they are bad enough.
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
