cherry red notch tranny probs
  • Thread starter Thread starter Dip In Traffic
  • Start date Start date Nov 27, 2004
D
Dip In Traffic
217
queens,ny
Nov 27, 2004
  • Nov 27, 2004
my new 5 speed notchback is giving me probs.... the other day i was driving around and i noticed it was getting harder and harder to get in gear..then i got to a stop sign and i couldnt move ....i pressed the clutch to the floor and all gears were locked out i just couldnt get into any....i then turned the car off...to see what happens... i pressed the clutch and it went into each gear with no probs at all .....what could it be????
while im down there ide like to get a new clutch kit and shifter as well at the quadrant and adjuster ...which ones should i go with ? im thinking more of less king cobra or centerforce the car is stock for now .. but i plan on doing something later on...
shifter wise im settling on the TRI AX or is there something better out there?
which is the best quadrant /firewall adjuster out there??
D
dude5l
201
Grande Prairie, Alberta , Canada
Nov 27, 2004
  • Nov 27, 2004
Sounds like your clutch is not dis-engaging. Check the cable, it may have stretched or partially broke to the point where it is still attached but won't dis-engage the clutch.
D
Dip In Traffic
217
queens,ny
Nov 27, 2004
  • Nov 27, 2004
im gonna check it out today....if its streched how do i adjust it???
04sleeper
2,674
14
89
Dallas, TX
Nov 27, 2004
  • Nov 27, 2004
If the stock adjuster is still in tact then you could try pulling up on the clutch pedal. If is working then it might pop up a couple of notches.
Might be worth a shot.
It's probably best to do your upgrades as mentioned though.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Nov 27, 2004
  • Nov 27, 2004
My guess is clutch cable stretched.
Try grabbing the clutch pedal. Pull up to you hard and then push the the foor as hard as it will go. It should click if it adjusts
D
Dip In Traffic
217
queens,ny
Nov 27, 2004
  • Nov 27, 2004
i tried what u guys suggested and nothing.....i noticed when i put the clutch in the cable in the engine bay wiggles side to side.....we ended up snapping the clutch quadrant messing around with it ....anymore idea's
D
Dip In Traffic
217
queens,ny
Nov 28, 2004
  • Nov 28, 2004
bump
D
Dip In Traffic
217
queens,ny
Nov 28, 2004
  • Nov 28, 2004
bump
D
dude5l
201
Nov 29, 2004
  • Nov 29, 2004
Get an aftermarket quadrant and firewall adjuster.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
