chrome radiator over flow tank question
90lxfoxbody
264
hi again, i have recently upgraded my cooling system with a black magic electric fan and 100 amp alternator. next i am installing an all aluminum radiator and i want to add a chrome or polished radiator overflow tank. most of the ones i see for sale have two outlets at the bottom of the tank. does anyone have one of these tanks, and if so how did you install it? did you block off one of the outlets and route the tubing just like it was on the original overflow tank? also i have found a blue adonized trans cooler and it would match the color scheme of my engine compartment nicely. can i use a tran scooler for an oil cooler? i know they work on the same principles and are made similarly, but is there anything structurally different about a trans cooler that would make it unfit to use as an oil cooler? thanks.
http://www.cantonracingproducts.com/tanks/expansion_tanks.html
