  • SN95 4.6L Mustang Tech
Engine Clacking Noise
  • Thread starter Thread starter Drich35
  • Start date Start date Dec 26, 2016
Drich35
14
  • Dec 26, 2016
Alright i have spent all day searching and this is what i have issues with. I just put an 03 4.6 2v engine in my 96 gt and as soon as it was started there was a clacking noise that sounded like valvetrain rattle but new head gaskets were installed, new lash adjusters and cam followers were all good. I also replaced the timing gears, chains, guides and adjusters. I cannot pinpoint the noise but it sounds like its right in the water pump area or favoring the drivers side. I took the valve covers back off and theres barely any oil coming out of the lash adjusters on the drivers side. There are no oil restrictors to check for gasket debris clogging. My only thought is that i got a bad timing tensioner out of the box. I have heard if a tensioner is bad it would affect oil pressure on that side. The sound is not a knock but more of a clack clack clack and not a tick sound either and its more center front of the engine.
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Dec 27, 2016
  • Dec 27, 2016
Don't think you have much choice but to tear down and check it out. Sucks!
Drich35
14
  • Feb 25, 2017
New video after timing tensioners replaced. Not quite a hard rod bearing knock but has rotational loud tapping. Would this be piston slap? Last ditch effort before i pull the motor again.
View: https://youtu.be/qEN0ISyfw2k
HawkX66
51
Michigan & Mass
Mar 25, 2017
  • Mar 25, 2017
Did you figure it out? Mine doesn't sound quite as bad, but it's a real similar sound. I did lash adjusters and the timing set, but it's still there.
Drich35
14
  • Mar 26, 2017
I havent completely taken it apart but all i can find is #5 has a lot of slop in the bore. Rod and main bearings are tight. I can make the clank noise by hand so i am guessing severe piston slap.
Drich35
14
  • Mar 26, 2017
HawkX66
51
Michigan & Mass
Mar 27, 2017
  • Mar 27, 2017
Responded in your other thread. Thanks.
R
Unidentified Ticking Noise
  • revised
  • Jul 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jul 11, 2026
MT94GT
M
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
SN95 4.6L Mustang Tech Nov 5, 2025
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
