cleaning 80mm Pro-M air filter
It says not to oil the filter on it??? I thought all K&N type filters get oil after cleaning. They normally make a recharge kit that has a cleaner and an oil spray can to apply after.. Ive always just used some water with a few drops of dawn soap and cleaned it.. then used the red air filter oil. Just make sure you let it air dry befor applying oil.. and dont use an air compressor to dry it out. It can actually blow the fabric out.
S/CBlack95GT said:
NOOOOO, do not apply oil to those filters. It is NOT a K&N type, it is gauze!! Just wash it out and let it dry. If you apply oil it will go through the filter and mess up the MAF element.
heh... I just checked mine.. its a K&N filter and I must have changed it out a while back im guessing.. it was red with oil when I bought it. Isnt the K&N a guaze type material also? Its been so long since I bought my Pro M I dont remember what the original filter looked like.
The Pro-M's dont come w/ K&N Filters on them but if you buy one used who says that the previous owner did not change it out since K&N does make filters to fit almost all applications.
rockin_rick said:
How do you clean this? It says do not oil. What do you clean it with, and is there anything that goes on it (like oil)?
Rick
Just use a soap and water solution and let it air dry....The Pro-M states on the filter..Do not use oil..
