  • 1994 - 1995 Specific Tech
Cleaning Headlights
  • Thread starter Thread starter RiceEatin1995GT
  • Start date Start date Sep 25, 2004
R
RiceEatin1995GT
21
West Palm Beach, FL
Sep 25, 2004
  • Sep 25, 2004
What can I do to make these clearer until I can get the new ones I want? The lights are kind of dim due to the poor visibility of the lenses, and it looks like crap. Any suggestions? Thanks.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 25, 2004
  • Sep 25, 2004
I used chrome polish and it does a pretty good job of removing the yellow. You can also wet sand it with at least 600-800 grit then polish it.
R
rudeone707
1,829
Fairfield, Ca
Sep 25, 2004
  • Sep 25, 2004
i always wondered why the head lights start to look like ass but the clears corners stay decent.
R
RiceEatin1995GT
21
West Palm Beach, FL
Sep 25, 2004
  • Sep 25, 2004
Alright, thanks man. Any other suggestions?
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Sep 25, 2004
  • Sep 25, 2004
If you have any mothers mag & aluminum polish that'll work too. It'll just take some hard rubbing to get them clear. The best way I've done it so far is wet sanding with 1200 grit paper, then using turtle wax cutting compound to remove the scratches. Mine looked just like yours and they looked almost new when I was done.
E
EpiKk3
405
  • Sep 25, 2004
I didn't even bother sanding but I used some mothers mag / aluminum polish and it really cleaned em up.. about as nice as you can make em look without getting new ones
SN95StangMan
1,292
Lynwood, CA
Sep 25, 2004
  • Sep 25, 2004
Does anyone know why that happens? I always laugh when I see a mustang that has some new clear corners and the dingy yellow headlamps.
I used some mothers aluminum polish on my stockers and it worked great. I tried to get it a little better by wet sanding them but I grabbed the wrong sand paper and scratched the hell out of them.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 25, 2004
  • Sep 25, 2004
only reason i can think of is the extra heat from the light
9
95mustang gt
32
scottsboro,alabama
Sep 25, 2004
  • Sep 25, 2004
whitening toothpaste works pretty good.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 25, 2004
#10
  • Sep 25, 2004
  • #10
Here is what mine looked like before.
Ignore the dorky guy in the car
Here it is now.
I used orange pumice hand cleaner, #0000 super fine steel wool, & glossy clear coat spraypaint.
Tape the rest of the car off with masking tape and garbage bags leaving only the headlights visible. Then use the cleaner to get all of the drit/grime off if it. Next use the steel wool to remove all of the yellowing. It will look very hazy when you are doing this. It's normal. You need to make sure all of the yellow is off of the headlight. It will take a lot of elbow grease to get it back to just a hazy white.
Once all of the yellow is gone, spray a THIN coat of clear on it. Let it dry, and repeat. 3 coats should be enough. Now, with the clear coat on, you can wax it, just like the rest of the car. No need to wax it now but in the future, if you want to, you can.
People think I have the "cobra clears" ever since I cleaned mine.
Scott
EDIT - Just as a note. Anytime you use spraypaint, you need to create your own "dust free enviroment". Once the paint is on, dust, hairs, etc love to stick to it before it dries. I use an cardboard box with the top cut off, and tape it so the painted object is surrounded by the box. It's not 100% dust free, but close enough for this purpose.
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
F
Black Headlight Area
  • frwgt350net
  • May 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Willybill32
