After I pulled my heads off, i noticed a bit of carbon buildup on the tops of the pistons. I used a wire brush and lightly broke up the carbon buildup then wiped it away. I also used a ratched and 15/16" socket to rotate the crank to push out the dirt that was in the bores. Anything wrong with the way I did that? Can I improve on anything to clean up the pistons?
