cleaning the IAC
avexhype
14
I need to clean my IAC motor. I have a bottle of automotive electronics cleaner laying around can i use that to clean the IAC? or do i HAVE TO buy carb cleaner? thanks
3M Throttle Body Cleaner and Q-Tips.
The IAC on my truck has been 'bad' for 2 years now. I clean it twice a year and don't have any issues. I know people who have already bought two in the past two years. Unless something is broken with it, cleaning it is all you need to do.
avexhype:
Contact cleaner will work OK. The routine is spray, brush, tap, repeat. You need a Q-Tip or small brush to get the "dirt" out of the IAC. Tapping it on the workbench helps to dislodge the stuff. You will be amazed at the volume of dirt that comes out. Do not spray up into the solenoid (it doesn't get dirty, lol). Try to clean all the dirt off the shaft and tip because it is metering air into the engine and if the shaft hangs up, the air flow will not be right for idle control (and other things). Watch that you do not tear the gasket when removing the IAC valve. Replace the gasket if there is a tear or you will have problems.
GL,
Chris
