'Cleaning' threads
  • Thread starter Thread starter kikboxr1
  • Start date Start date Aug 27, 2004
kikboxr1
289
Atlanta, GA
Aug 27, 2004
  • Aug 27, 2004
I'm going to change my spark plugs this weekend, and I'd like to do something I haven't done before - clean up the threads in my GT40 aluminum heads. I haven't used a tap before so I thought I'd ask first to make sure I'm not going to mess anything up. After using a cloth and a wire brush to clean off the old anti-seize, is it safe to use a tap to kind of straighten out the threads?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 27, 2004
  • Aug 27, 2004
Never use a tap to clean threads, especially on an aluminum head. There is too great a chance you will start the tap off center and cut new threads. It is very easy to cut new threads in the soft aluminum.
A spark plug thread chaser is what you need. Most good auto parts stores will have them. The thread chaser will clean threads but will not cut new ones.
If you have a Dremel or die grinder, use a small cut off wheel to cut 3 or 4 slots or grooves in an old spark plug along the length of the threads. done properly, it makes an excellent thread chaser.
Keep in mind that you need to use grease or similar material in the slots of the thread chaser to capture the trash the thread chaser cleans out of the threads.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 27, 2004
  • Aug 27, 2004
Hey there stranger! Why do you feel you need to clean them up? If the plugs come out fine, I'd simply use some NeverSieze on what you put back in.
kikboxr1
289
Atlanta, GA
Aug 27, 2004
  • Aug 27, 2004
Hiya Michael!
The reason I wanted to 'clean' my threads was because last time I changed plugs I remember them feeling a bit odd coming out and going in. It felt like they were slightly cross threaded or something.
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Aug 27, 2004
  • Aug 27, 2004
If you can turn them in and out by hand there is nothing wrong. I would leave it alone...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 27, 2004
  • Aug 27, 2004
I'm with Ray - if you can get them easily started with NeverSieze, I wouldn't worry about it.
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
Engine What’s your preferred way to clean engine parts prior to assembly?
  • Xam Sirrah
  • Jun 6, 2025
Fox 5.0 Mustang Tech Jul 5, 2025
Methodical
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
