Clearance
  • Thread starter Thread starter 1993mustang50
  • Start date Start date Apr 3, 2026
1993mustang50
  • Apr 3, 2026
Hello eveyone. Going to use 185 AFR small valve as cast heads with F303 cam. Anyone running this combo and will I have clearance (VP) issues? Using stock 302 block stock piston with stock valve reliefs
86HO5.0
267
179
53
Raleigh, NC
Apr 3, 2026
  • Apr 3, 2026
If in doubt, check PTV clearance.
Reactions: General karthief
AeroCoupe
6,238
4,331
183
Claremore, OK
Apr 3, 2026
  • Apr 3, 2026
Hmmm…dart board worthy or not?
What vehicle did the motor come out of and what yesr? This will determine the pistons which helps with potentially telling you if there will be interference issues.
As 86HO5.0 pointed out claying the motor is the absolute best way to know.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Apr 4, 2026
  • Apr 4, 2026
Looks like those heads were designed to clear, but you always have to check.
I also would not be using those heads with an F cam.
Only do this once, use a custom cam with them. It's not like you are using a $200 set of gt40p heads.
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
