clearing codes
  • Thread starter Thread starter Euphoric306
  • Start date Start date Nov 26, 2004
Euphoric306
905
  • Nov 26, 2004
.....possible? i cant seem to find any info in shop manuals or OTC manuals of how to clear the computer codes.... i kinda messed up and disconnected some sensors with the ignition on or the engine running and now im getting too many codes, some of which indicate bad sensors that i just replaced (prior to screwing up codes) like the coolant temp sensor and such....
think i might need a new ECA cuz ive replaced just about every other component of the EEC-IV, save a few sensors and actuators, and my problem still hasnt been solved. thanks for your help guys
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 26, 2004
  • Nov 26, 2004
If you used the jumper wire method of putting the computer into test mode, just disconnect the jumper while the engine is running. Scan tools like the Actron have their own method.
You can always disconnect the battery for 20 minutes and it will clear all the codes and reset the computer to "learn" new settings.
Euphoric306
905
  • Nov 27, 2004
ok thanks a lot, i tried disconnecting the battery for 30 sec. i thought that was the time to clear it but ill just do the 20 mins thing, thanks again
HISSIN50
34
129
Nov 27, 2004
  • Nov 27, 2004
after the battery is disconnected, some like to turn on the headlights, which should discharge any residual KAM charge.
following JR's sage advice is the best.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
