- Sep 2, 2004
- 466
- 0
- 0
I get a "Click...click...click...click...click..." from my front wheels when turning. If I make a right turn, the left-front wheel clicks. If I make a left turn, the right-front wheel clicks. Never both at the same time. And the click-rate increases as I speed up, and decreases as I slow down. What could this be??
Front suspension mod's include:
Tokico's
Steeda Bump-Steer
Steeda X2 Ball Joints
Polyur. sway bar bushings
Polyur. a-arm bushings
2" fixed-rate springs
4-bolt Caster/Camber plates
Replaced the front wheel bearings when I first got the car. A new power steering rack was recently installed before I bought the car also. But the clicking didn't start until after I did all the suspension mod's to the front. I did it all at the same time about a year ago... car was aligned immidiately after installation of course, and I've checked all of the bolts and bushings to make sure all is secure and torqued correctly. Don't know what is clicking.
Tokico's
Steeda Bump-Steer
Forgot about the basball cards...haha. I'm going to install a Tubular k-member, tubular a-arms and new calipers and rotors... that will replace the a-arm bushings. I might replace the wheel bearings again while I'm at it, and if the noise is still there I'll just replace the whole steering rack. Its loud, and annoys me... click...click...click...click...
I wonder if I damaged the wheel bearings or something inside the steering rack when I did the a-arm bushings. That was a chore! I remember fighting with the steering rack to get those a-arm bolts out and back in.
