Clunk coming from driver's side front end
Hey,
I posted this a few weeks ago, but, well.. with the server crash and all, I never really got a chance to see what people had to say.
Anyway, recently bought a 94 GT 5 speed with about 100k miles. Had a slight clunk coming from front end, drivers side, mainly happens during low speed turns and when the car shifts weight (like starting/launching from a stop, or coming to a stop). But NOT so much over bumps (extension/compression), which seems interesting.
Guy I bought it from told me he had it looked at and they said it was the front end bushings. Got the car in the air, bushings look pretty much ok for having 100k on them. Actually, nothing in suspension really looks suspect outright, so I'm kinda confused.
Car has Eibach Sportline springs, aftermarket CC plates, and KYB shocks. Steering rack bushings look like they should be replaced, but I don't know if that's related to this problem, but I'm pretty sure that those steering rack bushings are causing the inch-or-so of play in the steering wheel. But first things first - this clunk is pretty annoying. I'm a college student on a college student budget, so I can't really afford to take apart the whole suspension - I'm hoping to isolate this problem and deal with it specifically.
Anyone else run into this? Any suggestions? I took some pictures, don't know if they'll be of any use, but I'll post a few if someone thinks they'll help.
As i suggested before the big crash,I had an issue before like this and it ended up being a front universal joint on the drive shaft.So i replaced both while i had the drive shaft off.Once i got the drive shaft off the loose uni's showed there uglyness with having alot of play in them.It was an ugly clunk.
As far as it being a ball joint,these tend to squeek before letting go,i have had this happen,and trust me a broken ball joint raises the hair on the back of your neck when they go.
So go for checking the universal joints first.
I hope this helps.
Jack's95gt said:
It sounds like a control arm bushing. Don't wait until it breaks. Any repair shop will be able to tell you exactly what wrong in two minutes after it's on a lift.
The control arm bushings are what we had planned to replace. They look fine, there's no distorting of the rubber or any sort of significant damage at all. We took a pry bar to the various bushings to try and replicate that clunk with no result.
Is there a specific reason why you think it's the control arm bushings above all else? Also, the clunk doesn't happen over bumps, which seems to indicate that it's something other than a bushing, right?
I hope this helps.
OH YES i would say losing a ball joint raises the hair on the back of your neck..unless you like having your a-arm dug into the pavement and your wheel in your fender
I hope this helps.
Hmm.. for it to be a u-joint, it'd have to happen when it was in gear, right? Because it'll happen just when the car is a reaching a stop, and the weight shifts from slightly forward to a more level stance, and at that point, the gearbox is obviously in neutral...
Really feels like a front end problem. Tie rods, maybe? I don't know what sort of symptoms bad tie-rods cause, but I'm running out of front end parts as suspects...
You can just replace one. Usually they are a little more than $20.00 a piece. The outer ones are usually the culprit. You should be able to get a free exam at most stores and then they will do the labor, which is like a 5 min. job to remove them, and then align. They attach to the steering knuckle which is why they usually pop when you are turning. Now the inner rod can go bad to, but usually the outer one is the problem. They offer an "import" version for a little cheaper. Compare the 2 and you wont see one difference except a 3 month vs 1 year warranty. I have one for my 95 drivers side that I never installed because a deer took the car out one morning on my way to work. Never been used brand new. Give me your home address and we can figure S&H and its yours for free. Its just sitting on the shelf and I am moving. A lot of good it will do me. You dont have to pay me until you get it either. I trust you, cause I know where to call you out at. HEHE I am going out of town, so if you want it, tell me what the shipping is from 45133 to your address and PM me your adddess. I will get the box ready. You can send me the money Paypal or Money Order for the shipping. WHo knows it may be just a little more since your in California to just go get one there. Let me know bro.
