clunk noise
  • Thread starter Thread starter charlesw6954
  • Start date Start date May 15, 2004
C
charlesw6954
476
Mo
May 15, 2004
  • May 15, 2004
after i installed my alluminum drive shaft i have a clunk noise. did i install it wrong or something?
dastang2
2,020
tx
May 15, 2004
  • May 15, 2004
the bolts are probably coming loose. they back out if you don't use locktite
C
charlesw6954
476
Mo
May 15, 2004
  • May 15, 2004
it started doing it right after i installed it
HISSIN50
34
129
May 15, 2004
  • May 15, 2004
when does it clunk? (on decel, etc)....that is weird. i just got mine and was unimpressed with how they balanced it (not that i think you are having a balance issue - just a comment).
C
charlesw6954
476
Mo
May 16, 2004
  • May 16, 2004
anyone else? this happens when i let off the gas and it goes clunk. then i give it gas and it goes clunk. i can move the driveshaft (with my hands) freely for about one and a half turn before it stops. the u joints are ok.
R
Ryan91Saleen
173
Washington
May 16, 2004
  • May 16, 2004
i think the driveshaft is not supposed to move at all. thats maybe why its clunking.
dastang2
2,020
tx
May 16, 2004
  • May 16, 2004
either the rearend needs new gears or your u joints are out or the bolts, it could be the tranny too
G
GATOR98GT
185
BRISTOL
May 16, 2004
  • May 16, 2004
I have a clunck to. What is your exhaust setup? I have dumps and I found that the sound is the mufflers banging against the driveshaft. I didn't here it as much until I got the aluminum.
Cobra1894
196
Broken Arrow, OK
Aug 7, 2005
  • Aug 7, 2005
I have the same clunck on decel, I can move my driveshaft slightly if I really try. Anyone figured this one out yet?
D
DJFox
36
#10
  • Aug 7, 2005
  • #10
i had the exact same thing, a clunk under the under the car upon acceleration and then it would happen again once i let of the gas. It turned out to be the throw-out bearing. My only problem now is that I will wear out a throw out bearing in about 8 months with normal driving
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Aug 7, 2005
#11
  • Aug 7, 2005
  • #11
I had that when I mis-installed some gears and the pinion had too much play. If the pinion nut isnt tight, the gear will wobble and go clunk when it shifts from accel to decel and the gear jumps almost a tooth.
now...
It could very well be the exhaust. Look at a stocker and a aluminum side by side and see how the aluminum is much wider. When you accel, the motor tilts and the exhuast goes with it and could quite well smack the exhuast pipes.
D
Dagostang
12
#12
  • Aug 7, 2005
  • #12
my friend had a clunking noise, the rear frame was cracked it was the rear end smacking the subframe...
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Aug 7, 2005
#13
  • Aug 7, 2005
  • #13
I had a clunck a while back,it was the rubber bushing in the upper control are was complete gone.So it would moving slightly.
Check everything around the rear end,if nothing look wrong,I dont know what to say other than a gear install problem .But you said it wasnt doing it befor,so I dunno.
crazypete
Oct 22, 2004
930
Arlington, MA
Aug 8, 2005
#14
  • Aug 8, 2005
  • #14
In super super rare instances, the pinion nut can back off. The key to this is if you can wiggle the driveshaft... like rotationally. It should be solid.
Cobra1894
196
Broken Arrow, OK
Aug 8, 2005
#15
  • Aug 8, 2005
  • #15
I'm going to check the pinion nut (Is this the nut in the rear flange). I have some play back there and it is not the ujoints moving. I will try this as well. I have a feeling that its my tailshaft bushing causing play in the driveshaft... I get around to that.
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
