- Dec 25, 2012
- 240
- 16
- 29
Hi guys,
Probably seems like I have just one problem after another but at any rate, I am hearing a clunk when I turn left or right in what I believe is my passenger side front wheel. It seems to occur as I am getting out of the clutch and beginning a turn. I had an alignment done a little while back and they mentioned needing tie rods and potentially a wheel bearing. The tech did mention that I may be able to tighten a nut to take up any slack in the case of the wheel bearing (not sure why he wouldnt have done that). The driver side wheel looks like it is cambered to far out.
As a side note I did have the motor mounts loosened this weekend installing headers and I did tighten them as much as I could at the time. Not sure if a clunk could come from that or not.
Andrew
Andrew
