  • SN95 4.6L Mustang Tech
clunking everytime i shift
  • Thread starter Thread starter 5literstang
  • Start date Start date Oct 20, 2006
5literstang
1,374
Clark, NJ
Oct 20, 2006
  • Oct 20, 2006
i hear a clunk everytime i shift...u joints?
Brute03
232
  • Oct 20, 2006
i get that sometime when i go from 1st-2nd or 2nd-1st, it's like a thud
merc123
420
North GA
Oct 20, 2006
  • Oct 20, 2006
Driveline slack possibly.
M
MBDiagMan
171
Lamar County, Texas
Oct 20, 2006
  • Oct 20, 2006
In all manual transmission cars there is a small amount of slack. With manual transmission and clutch practice you will not feel NORMAL slack. If you have anything beyond normal, you will not locate the problem on an internet forum. The only way to locate the problem is to safely raise the rear wheels, get under the car and start turning things back and forth 'til you find the slack.
sgarlic
3,085
Oct 20, 2006
  • Oct 20, 2006
What clutch? Hopefully it isn't the OEM one with an s-trim.
5literstang
1,374
Clark, NJ
Oct 20, 2006
  • Oct 20, 2006
thats what i was thinking orginally, but someone told me that it could be ujoints, im jsut going to replace them and check for slack
BlackenedSVT
1,841
New Jersey
Oct 21, 2006
  • Oct 21, 2006
time for a louder exhaust, then you wont need to worry about the clunking
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Oct 21, 2006
  • Oct 21, 2006
Could be your U joints,jack up the snake,and twist the driveshaft back and fourth by hand,and watch the U joints while you are doing it.If that is good,and they have NO play in them,then it could be your trans.
5literstang
1,374
Clark, NJ
Oct 21, 2006
  • Oct 21, 2006
im going to work on it tomorrow so il let you guys know how it goes
C
coffinator6
11
#10
  • Oct 21, 2006
  • #10
i have the same sound. my u joints are good. i was told it is the shifter. i have the t-45. what do you have. its hard for me to get my car back into first from second and into reverse somethimes.
mike
5literstang
1,374
Clark, NJ
Oct 21, 2006
#11
  • Oct 21, 2006
  • #11
nah i have a spec stage 2 with aluminum flywheel
5literstang
1,374
Clark, NJ
Oct 21, 2006
#12
  • Oct 21, 2006
  • #12
mike
yeah i also have a t45 with a steeda shifter... im going to check the ujoints tomorrow cuz i didnt get around to it today.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Oct 21, 2006
#13
  • Oct 21, 2006
  • #13
I've made this interesting discovery in my car, that has been the same in two other 'Stangs. I had a bad clunk, and could never figure it out. I put in a new clutch, flywheel, throwout bearing, pilot bearing, pressure plate, shift fork and ball, u-joints, all new bearings in the rear end, and a perfect lash adjustment, and still had a clunk on shifting. Turned out to be the upper control arm bushing, where it mounts to the body. The inner steel piece that the bolt went through was too wide, and when the axle would move, it would clunk up there. I had a friend kick my rear tire from the back while I was under the car, and I saw the thing move. I'd check your UCA bushings, because this has been the same on two other Mustangs I have worked on.
5literstang
1,374
Clark, NJ
Oct 22, 2006
#14
  • Oct 22, 2006
  • #14
i have an IRS tho
Y
Yellow2002GT
148
Raeford, NC/ FT Bragg
Oct 22, 2006
#15
  • Oct 22, 2006
  • #15
I have the same problem too! Mine is and Auto and found out it was the UCA's also........If your suspension moves too freely or binds you will have noises!
"ED"
5literstang
1,374
Clark, NJ
Oct 22, 2006
#16
  • Oct 22, 2006
  • #16
yeah the ujoints seem to be good but there was a little play in my driveshaft..
BennyBlown2v
1,233
Carmel, INdiana
Oct 22, 2006
#17
  • Oct 22, 2006
  • #17
Lmao stock clutch here - 423rwhp/408rwtq Been blown for 12k miles and at this power level for around 6k miles. I took it to the track every week this summer.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
shift light
  • dirk shorter
  • Dec 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 29, 2025
