Cluster swap
Javeed,
You have two (2) options: You can swap the printed circuit board of your original cluster to the new cluster or have your ECM reprogrammed to the new cluster at a dealer ($) or friend that has this capability. All of this with the battery disconnected for the initial swap of course.
It's important to mention the model year of the car. The procedure is different depending upon the version of PATS used.
For example, the cluster of a 96 can be swaped without re-programming anything.
For the MY that require re-programming, the PATS board itself can be swapped to avoid re-programming.
Pats= passive anti-theft system. If you have a hand held tuner you might need to take it to a shop but they will be able to do it. But as burns stated, year model of the car will help us. Also, which cluster are you switching to?
im switching to the same year mustang which is an 02 but the reason why i was switching is bc of the lights that are on the new cluster.
Javeed,
how do i swap the printed circuit board step by step bc i really wanna swap them already just dont know how. thanks
Remove the headlight switch, remove the 2 screws that go up into the top of the dash and that piece should pop out. After that it will be 4 screws that are black, the gold screws you see are only for the clear plastic cover do don't worry about those. Carefully pull the cluster away and you will have 2 different harnesses to unplug. After that take it to where you can sit down and work on a bench/table. Pull then both apart side by side to compare each. You will now remove the 6 hex gold screws on the back of each ad take that part off. I'm pretty sure that will expose the circuits on the back and you might have to unplug 1 ribbon wire ad that's it, swap it into the other and that's it.
I'm not too sure why you want to do this swap for the same cluster essentially. You could do whatever they did to yours and it would probably be easier.
ok i did it and i thought it would switch the mileage on the car too bc my car has had gears on it ever since i got it and it through off the actual mileage on the car, so i calculated the actual mileage that it had and the new cluster that i bought was only like a hundred miles off. but i switched everything and it still has the same mileage..
Correct, when you swap out the brains of your cluster to the front of the new one it will have your original milage. Only way to get the milage of the other cluster is to install that back part as well. Problem with that is your car won't start since the pats system doesn't recognize it as the original and won't let you turn it on. Only way thy can be done is if you disable pats.
is there anyway to disable without having to buy a bypass system.
Do you have a hand held tuner like an sct? Pats actually does some good stuff but I have an aftermarket alarm and it does more than pats so I don't mind disabling it. I actually don't know if pats can be disabled without a tuner, I doubt it though.
