clutch cable adjust
  • Thread starter Thread starter drastangracin
  • Start date Start date May 31, 2005
D
drastangracin
11
  • May 31, 2005
I was wondering how i can adjust the cable to the adjust fork, the cable will not reach the clutch fork. Thanks a lot guys
J
jerry beach
2,671
Ocala,FL
May 31, 2005
  • May 31, 2005
Do you have an adjustable cable? If so it will adjust right where it connects to the fork at the trans. If not you will need a FWA (firewall adjuster). It goes on the firewall where the cable comes through on the engine side. The factory used a self adjusting quadrant, which is located above the gas pedal. What type of quadrant are you using?
D
drastangracin
11
  • May 31, 2005
How can you tell what it is, we have the bellhousing on and are trying to get the cable on but it wont reach the forks?? can you adjust it from inside the car on the firewall? thanks
H
hrspwrjunkie
165
May 31, 2005
  • May 31, 2005
Jerry Beach is right about an adjustable clutch cable. If you have a non-adjustable factory clutch cable, then you will need to perform this procedure: 1. Attach the cable to the clutch fork 2. Pull the clutch pedal all the way towards the driver's seat (this will release the quadrant). 3. With the clutch pedal pulled all the way back, push the quadrant up on the clutch cable retaining hook side. 4. Slide cable over hook and push cable end into hook recess. 5. Release quadrant and clutch pedal. 6. Step on clutch pedal and pull a few times to get quadrant to set cable to full tension.
H
hrspwrjunkie
165
May 31, 2005
  • May 31, 2005
You'll know by looking at the end of the clutch cable that attaches to the clutch fork. If it has a threaded end with a half spherical nut and a jam nut on it, it's adjustable, if all it has is a half spherical connector on it, it's non-adjustable.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
