Jerry Beach is right about an adjustable clutch cable. If you have a non-adjustable factory clutch cable, then you will need to perform this procedure: 1. Attach the cable to the clutch fork 2. Pull the clutch pedal all the way towards the driver's seat (this will release the quadrant). 3. With the clutch pedal pulled all the way back, push the quadrant up on the clutch cable retaining hook side. 4. Slide cable over hook and push cable end into hook recess. 5. Release quadrant and clutch pedal. 6. Step on clutch pedal and pull a few times to get quadrant to set cable to full tension.
