  • SN95 4.6L Mustang Tech
Clutch cable adjustment
  • Thread starter Thread starter stangboy999
  • Start date Start date Jun 13, 2005
stangboy999
399
Jacksonville, FL
Jun 13, 2005
  • Jun 13, 2005
Does anyone have a diagram of the clutch cable assembly on an 01' GT?
My clutch seems to be acting a little weird lately, it doesn't slip.. but it also doesn' feel like it's disengaging all of the way and makes a rubbing noise when I depress the pedal and slip it in 1st. I'm thinmking the cable just needs to be adjusted a little tighter.
Opinions? Ideas?
twogts4us
4,188
12
79
Dunedin, FL
Jun 13, 2005
  • Jun 13, 2005
As far as a diagram goes, well, it's pretty simple. It hooks into then goes around the quad, thru the firewall, thru a bracket near the front corner of the exhaust manifold, then back toward the trannie. At the trannie, remove the tin cup that hides the clutch arm and you can see where it fastens into it.
Is your cable and quad stock? Do you have a firewall adjuster?
stangboy999
399
Jacksonville, FL
Jun 13, 2005
  • Jun 13, 2005
yeah it's straight up stock, I was just trying to get a visual of the whole assembly so I could get a better idea of where the fault might be.. There is a firewall adjuster and I took a look at it yesterday, doesn't seem to be anything wrong with it. I'm trying to determine wether it's worth taking to the shop for repair, I'd hate to have to shell out cash for a 10 minute fix.
twogts4us
4,188
12
79
Dunedin, FL
Jun 13, 2005
  • Jun 13, 2005
For the stock quad, you can simply put the car in first, and pull up on the clutch pedal until it clicks. It's, essentially, self adjusting. At least, that's the theory. This does not work on my 02 however...I can pull at the friggin pedal until it's ready to break...it does nothing.
Anyway, here is a variation on that type of adjustment from Corral.Net - http://www.corral.net/tech/drivetrain/clutcha.htm
C
1992 5.0 Clutch Cable Adjustment
  • Chrispy62
  • Aug 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 28, 2024
Chrispy62
C
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
MM clutch pedal adjuster?
  • 2000xp8
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2024
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
