the fox body cables come with a bracket that holds them to the inner fender. It is a flat piece of metal with a rolled end to secure it to the cable. Using a screwdriver, pry open the rolled end to allow the bracket to come off the cable. Install the cable as it would be in your car. Find wherever it is hitting the header and make note of the nearest oil pan bolt. You will need a slightly longer oil pan bolt to replace the short stocker. While you're at it, get a few washers. Shorten the bracket to your needs, drill an appropriately sized hole for the new oil pan bolt, and re-roll the end so it is secure around the cable. My cable is about 3/8" away from the header and it holds up fine, but of course the farther away the better. Put the new oil pan bolt through the modified bracket, then stack the washers on top of the bracket(they will allow the bracket to sit flush instead of on top of the oil pan lip). Hopefully that's not too confusing. If I had a digital camera I would take some pics, but you'll figure it out. Good luck.
