Clutch Cable help
Hello I'm big issue i just recently bought my mustang n the clutch cable went bad, its one of those cheap adjustable clutch cables now the problem that i am having is that i cant find the same type of cable that i need.
the part that would connect to the quadrant is different then stock i belive this was custom work from previous owner
old cable part that connects to pedal assembly looks like this
i had bought an oem cable n looked at the adjustable cables and both of them had same type of head
THIS IS HOW THE PEDAL Assembly LOOKS LIKE (sorry best pic i could take Really cramped in there)
So does anyone know were i can find a cable like this one or if its from another type of vehicle that fits or do i have to change everything back
no there isnt a quadrant, but that shaft now is out of place isnt it because it should be sort of pointing foward shouldnt it but instead is pointing up, can i change that by loosening the nut in the beginning of the assembly?
i still cant belive i didnt realize that it was only missing the quadrant, thanks:nice:
there should be two shafts that the quadrant slides onto. both point towards the passenger side of the car. i don't fully understand when you say the shaft is out of place but it could be bent now, since the cable was directly hooked up to it and it alone.
Basically what i was asking is that my shaft that holds the quadrant is pointing directly up, n i was askin if i could move the position of that part but i figure i should try it to explain it better
on this one its pointing down:notnice: n on mine its sort of backwards pointing up :nice: it would be upside down so i was asking if i was able to move the position of that towards the correct one.
i think i can change that just wanted to make sure if anyone could tell me.
