  • SN95 4.6L Mustang Tech
Clutch Cable Problem after Clutch Replacement?
  • Thread starter Thread starter Timin
  • Start date Start date Jan 13, 2004
T
Timin
207
Houston
Jan 13, 2004
  • Jan 13, 2004
I put on the Steeda Firewall adjuster and got it to the place I like it to engage at. The pedal vibrates when driving and on startup, and I have still not figured out this problem. At 68k I wouldn't think the clutch cable itself would need to be changed? My friend said that the cable itself seemed loose and that it should be tighter. Could a loose cable be causing the clutch pedal to vibrate? If so how can I tighten it?
C
claytucc3
825
Santa Clarita, Ca
Jan 13, 2004
  • Jan 13, 2004
I think that you are supposed to change to an adjustable clutch cable when you install either the firewall adjuster or the clutch quadrant. Also, I had to trim the plastic part of the clutch cable that goes into the firewall when I replaced my clutch cable. I did all three at the same time. Otherwise the ONLY other way to adjust the cable is using the quadrant uinder the dash. To do this you pull up on the clutch pedal and it automatically adjusts.
Clay
T
Timin
207
Houston
Jan 13, 2004
  • Jan 13, 2004
Yea I messed with the quadrant and messed with the engagement there too. If I went to far it started to make the loud ticking noise just like the TOB's sound on our cars, so I moved it back far enough so that it wouldn't make the noise. The clutch engaged where I wanted it to, but then I noticed the Pedal would vibrate on cold startup and make a loud tapping noise. So I ordered the Firewall adjuster and it quieted the tapping noise on startup, but the pedal still vibrates some on start and while driving. So I guess that is my final problem is the pedal vibration that I am receiving.
-Karl
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
