  • 1994 - 1995 Specific Tech
clutch cable problems
  • Thread starter Thread starter Blackened302
  • Start date Start date Nov 1, 2006
First Prev 2 of 2
Blackened302
1,439
South TX
Nov 3, 2006
#21
  • Nov 3, 2006
  • #21
ok, can add a little more:
the clutch is the stocker--not a fresh install.
i tried using the second hook and that's where it started slipping majorly--the clutch wasn't even completely engaged because it was so high on the pedal.
verified that the quad is on both pegs.
the way the cable sits right now, it's mounted freely--there is nothing that is holding it back or in place except for the end at the ford and the other at the firewall.
hope that helps.
fawcett
380
Cohasset, Ma
Nov 4, 2006
#22
  • Nov 4, 2006
  • #22
As stated above, if you cant make things fit with the fwa, make adjustments on the clutch fork end. Ive done the cable on my car, this shouldnt be giving you so much trouble.
Hook it all up, set your fwa tight to the firewall (no slack taken up yet) jack the car up, get under it, tighten the cable hooked up to the clutch fork. This is a pita b/c as you tighten it the cable wants to twist-not actually tightening the cable. If you cant get it to tighen sucker a buddy into getting under your car and have him hold the cable in place while you tighen the nuts. This should get you close, take 'er for a ride make your fine adjustments at the firewall.
This worked for me with my t5 and t56 using Steeda products.
Good luck
HISSIN50
34
129
Nov 4, 2006
#23
  • Nov 4, 2006
  • #23
Fawcett, I believe he has a non-adjustable cable.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 4, 2006
#24
  • Nov 4, 2006
  • #24
what does youe firewall adjuster look like?
Blackened302
1,439
South TX
Nov 4, 2006
#25
  • Nov 4, 2006
  • #25
fawcett: Jt's right--my cable is non-adjustable.
HISSIN50
34
129
Nov 5, 2006
#26
  • Nov 5, 2006
  • #26
I have the same FWA (Extreme) and it worked well for me. That's neither here nor there - just to say that it can work. I think Jeremy's idea about the hook placement on the quadrant might be where an issue lies. A different quadrant (ugghh) might fix things.
I almost got a 3 hook but went with a single instead.
Good luck bud.
badstang123
397
Santa Clarita, CA
Nov 5, 2006
#27
  • Nov 5, 2006
  • #27
If I were you I would buy a new cable. I got mine from D&D Motorsports for like $25. It is adjustable and has been holding up fine on my Mcleod Clutch.
V
v8only
2,378
22
49
Nov 5, 2006
#28
  • Nov 5, 2006
  • #28
is your cable mounted under the motor mount? Is it REALLY stiff to push, or is it no too bad?
IDK, I'm thinking it "could" be a clutch issue, I've never heard anything like this b4, we've nearly eliminated the quadrant, fwa and cable from the pic. FYI, I've used that exact fwa b4 no issues
urban96
3,464
Syracuse, NY
Nov 5, 2006
#29
  • Nov 5, 2006
  • #29
ya maybe your clutch is on its way out
Blackened302
1,439
South TX
Nov 6, 2006
#30
  • Nov 6, 2006
  • #30
not sure about my clutch going out. we'll check that, though, in a couple weeks when we take my engine/tranny out.
the pedal feel is actually really smooth.
First Prev 2 of 2
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Clutch adjustment
  • Bill1xl
  • Oct 12, 2024
1994 - 1995 Specific Tech Oct 12, 2024
