Clutch cable snapped
  • Thread starter Thread starter 91foxbod50
  • Start date Start date May 17, 2008
9
91foxbod50
486
  • May 17, 2008
My cable snapped on my way home from work yesterday. I had to push my car in the rain. Anyway i went underneath to check and it snapped from the fork. I get the new cable on tuesday along with a steeda quadrant. Any recomendations because i want it to be done right and avoid this from happening again. I have a king cobra clutch kit. My main concern is maybe the throwout bearing was thrown off?
This is going to be a backyard job
93 LX
3,081
Norwalk, CA.
May 17, 2008
  • May 17, 2008
change the cable and you will be fine. The throwout is attached to the fork which rides on the inputshaft / bearing retainer.
The real question is why you pushed your car home instead of driving it? You do know you can drive the car by shifting without the clutch. At spot lights turn the engine off, place it in 1st gear then when the light turns green just use the starter to get things going. Yes its hard on the starter but it will get the job done.
Late....
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 17, 2008
  • May 17, 2008
PLEASE tell me you didn't just order an adjustable cable to replace your broken one. If so, you're bound to experience the same incident again, as those kinds of cables tend to snap on the clutch fork end...
A FORD non-adjustable cable with a firewall adjuster and an aluminum quadrant are the way to go. Period.
BOTTLE_FED_FOX
12
  • May 17, 2008
darkwriter is right. adjutable cables are garbage return it before its too late along with that quadrant. stock cable and mm quadrant and fwa is where its at. trust me on this one. i bought it and i won't go back and everyone i know that has felt my clutch ripped their bbk crap out and bought my set up.
91green5.0
33
Middle Granville NY
May 18, 2008
  • May 18, 2008
I had the same problem with my old mustang it has the adjustable quadrant, i heard it was a good thing to have, dont know much about it but the cable snapped so i put my stock one back on it. I drove it home too!
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
May 18, 2008
  • May 18, 2008
I prefer the stock quadrant for a car that sees alot of miles.
Forgetting to adjust a firewall adjuster can be a very bad thing.
The KC clutch isn't all that hard on the leg.
IMO, get another stock cable, and put it in.
F
Foundmy84
Nova Scotia, Canada
May 18, 2008
  • May 18, 2008
I also recommend the stock cable... I went through 2 aftermarket ones CRAP.. stock cable is the way to go!
87foxstang
Cromwell, CT
May 18, 2008
  • May 18, 2008
that sucks. Happened to me last weekend. I went with the ford original one
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 19, 2008
  • May 19, 2008
"Forgetting" to adjust the FWA? I've had the clutch cable on the notch that I used to have (Frankenstang now owns it) set on almost the exact same spot as it was when I first put the FWA and UPR quadrant on there 3 years ago, and I've only had to adjust it once simply to suit my preference for where the pedal "catches." Constantly having to adjust the cable tension is usually a sign that the cable is stretching out, which is usually caused by:
1. A cheap aftermarket cable (usually the adjustable ones, or cheap-o non-adjustable OEM-wannabe replacements)
2. Improper routing of cable that results in binding (running it too close to the headers and such)
3. Misalignment or crappy quadrant fraying or stretching it out at the dash end of the cable.
blckstng96
208
#10
  • May 19, 2008
  • #10
i've always had steeda cables and they are by far the best.teflon lines so they are incredibly smooth and they take nowhere near as much effort as any other one.ive had a hays,piece of ****,bbk just like everything else they make-****.stock or steeda.my steeda was in my car for a 6yrs and change,just broke a few months ago.
redredline
#11
  • May 19, 2008
  • #11
What he^^^ said. DONT go w/ the adjustable. Just bad news.
9
91foxbod50
486
#12
  • May 19, 2008
  • #12
Man i regret ordering the steeda kit. lol. i orderd a oem cable so when the steeda goes i'll put the oem cable in. Thanks guys
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
