Didn't want to hijack another thread so started this..
I have a new flywheel, clutch (Luk), and transmission with less than 5k miles on them. Ever since I got the work done, I've had clutch chatter when the pedal is up. The noise is like a squeak definately caused by something rotating. The noise goes away when I put the clutch pedal in a couple inches.. not enough to disengage the clutch (not sure if its enough to slip the clutch), just some pressure. I would think its the throwout bearing... but I just got that entire chunk of my car replaced.. why would it still be making noise? Could they have reused the old TO bearing?
I read somewhere on here that a maladjusted clutch cable can cause the TO bearing to squeak too. Is there something I can do to my cable adjustment (remove slack? something about "zero lash"..?) to see if it removes the noise without replacing the TO bearing? Cable and quadrant are all stock..
This noise drives me crazy. Any help would be appreciated. The shop that did the work say they can't fix it, its something that "sometimes happens" but doesn't cause any harm or damage to the clutch assembly... is this
or are they right? Regardless, I'd like to get rid of it if its easy/cheap to do.
Even drove the car up north to school. The noise is worse in the cold...
