  • SN95 4.6L Mustang Tech
clutch doesnt feel right
  • Thread starter Thread starter 35th99gt
  • Start date Start date Nov 1, 2006
35th99gt
33
  • Nov 1, 2006
ok so for a while now much clutch is still real laaame. ive adjusted it many times many ways, at the firewall, near the bh, and at the quadrant. it just doesnt feel right. every time i press it in while driving it feels like its scraping against something... or almost "crunchy" feel. and there are many times when i cant put it in gear once i come to stops, or try and go in reverse. any ideas on wut it is before i take it to my mechanic?
(aftermarket cable,FW adjuster, quad, CF clutch, alum. fw) if that helps any. when i first had it put in it was reeeal soft but then it seems to be much stiffer now
R
Red2000GT
2,450
Regina,Sask.Canada
Nov 1, 2006
  • Nov 1, 2006
Sounds like throwout bearing or clutch cable.Most likey throwout bearing.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Nov 2, 2006
  • Nov 2, 2006
it's probally the cluch cable. my aftermarket one only lasted about a year before it was junk. I wished I modified a stock cable to work with my firewall adjuster.
35th99gt
33
  • Nov 2, 2006
if it as a bad tob will that mess any other parts up?? and should i fix it asap? i'm pretty sure its not the cable ive taken it out at looked at it and looks fine... but u never know.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 2, 2006
  • Nov 2, 2006
Who installed your clutch?
35th99gt
33
  • Nov 2, 2006
friends friend at his shop. they all work on cars and i figured he knew wut theyre doing since he's been building cars since 95.
Mike97gt
it doe snot
10,633
Nov 3, 2006
  • Nov 3, 2006
The crunchy feeling and not holding adjustment is a sign that the cable is stretched and failing. If it's the TOB then you need to drop the tranny and install a new one. not being able to get it into gear is because the cluch adjustment is too loose, you don't have enough clutch air gap to allow gear engagement, so pretty much your clutch is staying partially engaged this makes it HARD to get into gear at times.
Rickyll7
718
  • Nov 3, 2006
crunchy huh? i guess my crappy cable is about to go too. time to get a stock one as i should have before
Rickyll7
718
  • Nov 3, 2006
so where is the best place for 35th99gt and I to buy a stock cable from?
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
