  • SN95 4.6L Mustang Tech
clutch fork return spring
  • Thread starter Thread starter soupnutz
  • Start date Start date Sep 18, 2009
soupnutz
73
Hampton Roads, VA
Sep 18, 2009
  • Sep 18, 2009
I found a link to an article on how to hook up a clutch fork return spring, however the thread is 6 years old and the link isn't good anymore.
I can think of a few ways to possibly rig it up, but does anybody know where to find a writeup on a proven way to do it?
K
komplex
  • Sep 28, 2009
Any luck finding this? I am having the same problem with my fork pushing my throwout bearing against the pressure plate. If I can't find anything I will try to put something together and make a tutorial. I am thinking of putting some kind of sleeve around the spring so if the spring was to ever break, its pieces wouldn't end up inside the bell housing.
Greenscobie86
132
The Island NY
Sep 28, 2009
  • Sep 28, 2009
I'm interested in this as well.
I remember some company I saw online selling such a kit, but I cant find the link now.
squeak93
2,344
415
164
Joplin, Missouri
Sep 28, 2009
  • Sep 28, 2009
A return spring would be a band aid at best...
If your fork/tob is putting too much pressure on your pressure plate then you have other issues. Get and adjustable cable or firewall adjuster to lengthen the cable to relieve the pressure.
K
komplex
  • Sep 28, 2009
I see when the clutch is out the cable would push is back, I guess the cable or whatever is under that rubber stuff on my stock cable is shot. I will get a firewall cable, quadrant and new cable.
soupnutz
73
Hampton Roads, VA
Sep 29, 2009
  • Sep 29, 2009
That's what I want it for, a band aid. Until I have time to change my throw out bearing, and pressure plate. Some of the fingers stick out more than others causing constant contact with the t.o.b.
squeak93
2,344
415
164
Joplin, Missouri
Sep 29, 2009
  • Sep 29, 2009
Good luck.
I don't see how this could work and if it does, your pedal pressure is going to be crazy hard.
4.6andSlicks
171
Central Connecticut
Sep 29, 2009
  • Sep 29, 2009
I did this on my own after I lost the first throwout bearing at 40K. I have a Tremec 3650 and basically went to the hardware store and purchased a couple of springs that I thought would be a good fit and a couple of "S" hooks.
Without the dust cover on, I hooked a spring to the fork and to the tranny cross member and when I got it where I wanted it, I punched a hole in the back of the dust cover to make room for the spring. You don't need much tension to do the job.
It works fantastic for the last 15K for about $5 worth of parts.
Pedal pressures not hard at all. Since the spring is longer, it's the same tension from top to bottom of the pedal.
If you're using it as a band aid. When you finally change the throw out bearing, replace the spring and you'll never have to replace one again.
Cables can't "push" the fork, which would pull the bearing off the pressure plate. You need a spring to do that.
I wish I had pictures because I truely think this is one of the best (and cheapest) mods I did.
Speeds8erM-1
1,240
Pensacola Florida
Oct 17, 2009
  • Oct 17, 2009
LDC Chicago Clutch Freeplay Correction Kit [LDC-FREEPLAY] : Lethal Performance, Performance parts for Ford Mustangs
Hello from Minnesota (and the ancient MustangBoards)
  • SpeedofDarkness
  • Aug 24, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 24, 2025
SpeedofDarkness
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
