  • SN95 4.6L Mustang Tech
Clutch fork!!!
  • Thread starter Thread starter MACH_WON04
  • Start date Start date Apr 16, 2009
M
MACH_WON04
18
  • Apr 16, 2009
so does anyone know if a bad clutch quadrant could lead to a loose clutch cable which could lead to the clutch fork rattle and squeak at about 1500-2000 rpms? so i finally jacked up the stang removed the cover and found out that my clutch cable is loose which makes the clutch fork wiggle since there is no tension. from what im guessing is that from the flywheel and everything else rotating its causing the clutch fork to rattle since there is no tension! so im thinking about purchasing the steeda clutch adjuster kit and this would fix my problem! anyone out there that would know or has had this issue?
Steeda Mustang Clutch Adjuster Kit (96-04) at AmericanMuscle.com - Free Shipping!
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 17, 2009
  • Apr 17, 2009
Once the cable stretches after use you will have this issue. A firewall adjuster should solve it.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
