Clutch fork!!!
MACH_WON04
18
so does anyone know if a bad clutch quadrant could lead to a loose clutch cable which could lead to the clutch fork rattle and squeak at about 1500-2000 rpms? so i finally jacked up the stang removed the cover and found out that my clutch cable is loose which makes the clutch fork wiggle since there is no tension. from what im guessing is that from the flywheel and everything else rotating its causing the clutch fork to rattle since there is no tension! so im thinking about purchasing the steeda clutch adjuster kit and this would fix my problem!:shrug: anyone out there that would know or has had this issue?
Steeda Mustang Clutch Adjuster Kit (96-04) at AmericanMuscle.com - Free Shipping!
