What do you guys recommend for a new clutch??? I need a new one, daily driver, little to no track duty for the 302... something basic. If the Autozone version works well, then so be it.
Also, when I bought the car, it had Eibach springs installed. Got new rear tires the other day, and took a look at the insides of the fronts, and they are wore down to the cords. Does it just need an alignment? Will it need castor / camber plates??? Are those only needed if they cant adjust the alignment enough? Can any shop do an alignment on a lowered stang?
Also... how can you tell if the rod ends / wheel bearings up front need to be swapped out... and where can you get them, aparantly AZ only sells the complete bearing / hub assembly, but Discount has bearings.
