Clutch Help Please
Stumper302
Detroit
So I have owned my 90 gt since 02 and bought it with 64k original on the car. I bought it from a guy who only owned it 2 months and was friends with the original owner. When I got it I was also given information about the upgrades and maintenance non of which said anything about a clutch replacement. So I drove the car sparingly for the next few years, and the last time few times I drove the car I noticed the clutch wasn't grabbing like it should. For instance if I got on it and shifted and released the clutch it seemed like it would hesitate before it would grab and wouldn't grab that next gear like it should. I also noticed that I would have to push the clutch all the way into the floorboard to get it started.
So fast forward 2 years I am ready to get the car back on the road and ordered a new clutch assembly and cable to replace what I thought was original clutch at 93k. I yanked everything out on Sunday and when I finally got the old clutch out it doesn't even look that worn, the flywheel looks nearly new, but the pressure plate looks stressed. I also pull the old cable and line it up next to the new one and notice it's stretched out a little bit.
Which leads me to think that was my problem all along. Also the rear main seal was leaking a little bit too, nothing serious at all. I have since been informed that sometimes with a rear main seal leak some of that oil can get on the clutch and cause slippage as well. I have pics of the flywheel, both sides of the clutch, and pressure plate. The pics available but the limit is 78.1mb??? Any advice, or has anyone else had similar problems.
Since you already have it a part, you might as well replace everything. Put a new rear main seal, have the flywheel resurfaced and install the new clutch & cable. I just put a Center Force duel friction clutch in my car and it grabs so good it feels like I have more horsepower. Good Luck
It probably has the junk adjustable plastic quadrant assembly and if so you should replace it with an aftermarket piece. The stock plastic one is adjustable.. you pull up on the clutch pedal and the push it to the floor. They tend to strip out tho.
i just do everything
resurface
clutch
t/o bearing
cable
firewall adjuster
quandrant.
Just put the steeda set up in my 02 works great and great price. latemodelresto.com
