clutch help
  • Thread starter Thread starter Stanger16
  • Start date Start date Nov 1, 2011
Stanger16
76
Connecticut
Nov 1, 2011
  • Nov 1, 2011
hey guys.. to start off i know this is the 4.6L forum and i have a 3.8L and i know someone will tell me in a suggestion to get a clutch that is attached to a V8, which I agree with if I had the money to do right now but that is not the case. I wind up asking in here because every time i post in the V6 forum i get no help what so ever. There is more activity in a morgue then that thread.
So here is my question:
My 98 V6 with 190,000 just blew what I am most sure in the throw out bearing since i just put in a new cable and when I turn the car on I can't get into any gears. SO I am looking to purchase a clutch kit for my car. I know there are tons of options out there and I was just wondering if some of you could point me in a better direction than I am in now. There are no mods done to the car but I do have plans to put on some bolt on and maybe down the road a turbo or supercharger, but i may have a V8 vert by then.
Any help would be greatly appreciated!!
fiveohwblow
Official Member
2,169
145
155
Nov 1, 2011
  • Nov 1, 2011
Oem.
N8Dogg98
3,872
238
184
MN
Nov 1, 2011
  • Nov 1, 2011
+1 to OEM
BULLITT5228
77
CENTRAL TEXAS
Nov 1, 2011
  • Nov 1, 2011
Yep... OEM. Do it right the first time and save yourself some grief.
Stanger16
76
Connecticut
Nov 1, 2011
  • Nov 1, 2011
so the RAM and Spec kits are no good?
N8Dogg98
3,872
238
184
MN
Nov 1, 2011
  • Nov 1, 2011
Why bother spending money on a clutch kit that will hold over 400 ft lbs of torque when you have a V-6 mustang with less than 160 RWHP? Seriously dude WTF? You won't have the driveability or nice pedal feel of an OEM replacement clutch with some fancy aftermarket unit and at your power level it would be a pain in the ass to drive around with anyways.
Of course some of the RAM and Spec kids are good (I have a RAM HDX clutch in my car), but at your power level it is retarded to spend money on a clutch when an OEM unit is more than adequate. FWIW, the OEM clutch is probably good to at least 300-350 lb-ft of torque and you wouldn't see that kind of power out of your V-6 unless you were shoving 15-20 lbs of boost into it.
fiveohwblow
Official Member
2,169
145
155
Nov 1, 2011
  • Nov 1, 2011
I have the spec stage 2, and it's considerably stiffer and as Nate said, not necessary.
Not a bad question to ask, but as you can see OEM will be your best choice.
Stanger16
76
Connecticut
Nov 1, 2011
  • Nov 1, 2011
hey i'm all for spending less money on the OEM.. I just didn't want to buy an OEM and be told down the road that i need to upgrade because of the hp..
fiveohwblow
Official Member
2,169
145
155
Nov 1, 2011
  • Nov 1, 2011
Despite what is said, oem will do a damn good job. If you're worried, go with a king cobra setup from ford. Mine held 500+ HP damn well.
Green&GoldGT
302
Virginia
Nov 1, 2011
#10
  • Nov 1, 2011
  • #10
Stick with OEM clutch and throw out bearing. I went with a Hays and it had a ton of clutch chatter. What's more annoying is everyone who rides in your car has to ask why it's like that. Luckily my Hays went out and now I have an OEM 03 cobra clutch ready to go in. Don't forget to resurface or buy a new flywheel.
flstang65
1,484
135
94
SE Georgia
Nov 1, 2011
#11
  • Nov 1, 2011
  • #11
Another +1 for OEM.
Stumbaugh
903
Russellville, Ar
Nov 1, 2011
#12
  • Nov 1, 2011
  • #12
Spec stage 5.
Oem is all you need brother.
Stanger16
76
Connecticut
Nov 2, 2011
#13
  • Nov 2, 2011
  • #13
thanks for the help guys.. is it better to go directly through ford or just get it off line?
N8Dogg98
3,872
238
184
MN
Nov 2, 2011
#14
  • Nov 2, 2011
  • #14
See if you can find a deal on the internet. I don't know who manufactures the Ford replacement clutch kit, but you can probably find that same clutch on the internet w/o the Ford name for a steal. For example, Rock Auto sells the SACHS OEM replacement clutch kit for around $150 (includes pressure plate, release bearing, disk, and install tool).
fiveoho
1,958
TN
Nov 2, 2011
#15
  • Nov 2, 2011
  • #15
do not buy a spec clutch. ive driven three mustangs that had them and hated driving every one of them. its either on or off, no in between. its a lousy street clutch.
oem ftw.
Stanger16
76
Connecticut
Nov 3, 2011
#16
  • Nov 3, 2011
  • #16
ok so here is yet another question.. I have been looking online for oem replacements and the two brands I keep running across are: Valeo, and Sachs. Does anyone have an opinion on either of these two? There is not much in the difference of price so i would rather get the better of the two instead of the cheaper of the two.. And would you guys recommend getting another flywheel instead of trying to re-use it. The flywheel has 190,000 on it and the dealership put a new throughout bearing in at 85,000 when i brought the car so i do not know if they already re-surfaced or cut it..
N8Dogg98
3,872
238
184
MN
Nov 3, 2011
#17
  • Nov 3, 2011
  • #17
Sachs > Valeo IMO.
No reason to buy a new flywheel. Find a local machine shop that will resurface it for you. Some machine shops will just swap it out for like $60-$100 (they take your used flywheel, and give you another used resurfaced flywheel in return).
fiveohwblow
Official Member
2,169
145
155
Nov 3, 2011
#18
  • Nov 3, 2011
  • #18
Just paid $40 to resurface my flywheel. It was checked like a mother***ker too.
Stanger16
76
Connecticut
Nov 4, 2011
#19
  • Nov 4, 2011
  • #19
any other opinions on Valeo and Sachs?
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Tuesday at 7:10 PM
LILCBRA
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
